Hi 2 all.
Please, help me to solve the “problem”. I can’t find the adapter for X100V to use standard light filters (for example 52mm). As I know, the thread on X100V lens is 49mm. Unfortunately, there are not many filters for this size.
please, give some links on the adapters, or give me some advice on what to do.
Thanks
  • Olaf W. changed the title to Filter adapter
Are you referring to step-up rings?
https://www.bhphotovideo.com/c/product/1068071-REG/sensei_surpa_4952_pro_49_52mm_aluminum_step_up.html
There are plenty of different sizes available, most camera supplies stores either have them in stock or can get them for you. As a note, get the brass ones if you can, they work better in cold weather, but cost a bit more.
p.s. Welcome to the forum.
