Just for the record: this discussion is useless. If it is f11 or f16 does not matter that much, since it is in any case much less than any 2.8 or 4.0 optics and that is my point.
Given that I am not a "tele photographer" at all (I would better have kept my Canon system for the shier amount of teles otherwise), I repeat: its for sure a great lens in the right hands and I do not doubt its usefulness.
Its just not for me.
By the way: the more expensive 4.8 lens is no alternative for me, since you are right - its just one stop more....
On the other hand I am looking forward to buy a 90, and that is a far as I need.
pretty clear.
you never used this lens, have only read something about it , refuse to look at and comment on the pictures shown, and declare that it is not for you ( though saying is a great lens!) but have never used it or can say anything  based on direct experience about its use and qualities.
No further questions your honor, I rest my case.
I am extremely calm, but am an articulated writer who likes explaining his thoughts making them clear. Don’t confuse anger with the full expressing of someone's thoughts, experiences and ideas most of the times based on direct experience.
I enjoy life to its fullest.
A very good day to you too Sir. Buy your 90mm and be happy. I won’t comment on this lens ( the 90mm) despite having a little experience with it , having shot a few pictures in a shop, but, unlike you with no experience with the 50-230 but holding an opinion about this lesn,  I consider it too little to give an informed opinion on it.
An occasional shot from that lens.
128mm 1/90sec f/9 iso1600
Look at the charts of a great many lenses at http://www.photozone/ and a trend emerges. Very fast lenses increase their center sharpness until about f/4.0 with slower lenses hitting their peak in the range of f/5.6 to f/8.0. Almost universally, f/11 shows some drop-off. By f/16-f/22 the drop-off is terrifying. No matter now widely absolute numbers may vary, the charts follow the same pattern.
Oddly, it does not show much difference when actually making photographs—without pixel peeping. Even in the optical lab, the difference between f/8.0 and f/11 tends to be quite minimal. This holds true for pretty much every lens they have tested, no matter the focal length. For your own information, shoot the same shot at f/5.6 and at f/16. Make prints and compare.
Just got the 50-230mm OIS when it was on sale the other day for $240.  Actually, I didn't notice that I got the older version until I already paid for the unit.  I tested it at the store vs the 55-200 and surprisingly the 50-230 was sharper.  I tried 2 copies of the 55-200 just to be sure.  Maybe I just got lucky and found a very good copy.
In terms of physical lens quality, the 55-200 wins HAND DOWN.  That lens is a beauty although its much heavier.  So far I am happy with the 50-230 and will try some soccer shots tomorrow :)
By the way, is there a visible exterior sign of which version is on the shelf? I believe both lense and package should be properly labeled for a new version.
I came back to my trip to Spain and I'm in the process of selecting and editing the images.  Here are some with the 50-230mm
21553461944_299ff48fda_c.jpgAt the park. Parque de la Ciudadela.  Pamplona, Spain by Marcelo Valente, on Flickr
230mm f/6.7
22163620762_ec1a20b291_c.jpgIndian Sikhs and their wifes at the Parque de la Ciudadela.  Pamplona, Spain by Marcelo Valente, on Flickr
171.6mm f/6.7
I also saw the OIS II packaged as a kit lens.  Tested it with the old version and could not feel much difference.  Yes, the only difference in marking is on the face where there is an OIS II marked.
Compared both copies and the older one was tad sharper so I'm happy with my buy.
strange since, optically, the two lenses should be identical the only difference should only concern a slightly extended OIS and a closer up focussing distance.
I can’t imagine how this would result in a lower performance of the newer type but there you go
Should be the copy of the lens.  Could be I was lucky that i found a really good copy, or by chance the 50-230mm kit lens was a bad copy.  During my test, the older version was a little bit sharper, not by much so it really could just be the same for most samples.
Hey, did you happen to go to Piémanson? I read this article and it seemed like a fascinating place, reading your post reminded me again of it (some great photos in the article too, pulled from a photo book)-
http://roadsandkingdoms.com/2014/last-days-of-a-wild-beach-qa-with-vasantha-yogananthan/
My tribute in Camargue 2014 om X-E2 Jpeg Velvia simulation..
Love my copy of this lens, Bargain!!!
  • 11 months later...
It never ceases to please me ...
Eilat Mountains.
A kind of remote landscape with compression.
Looks a bit flat though.
Taken from hotelarrow-10x10.png balcony through the small gap between the surrounding buildings. :)
    • I have analog film recipes in C1 through C6 on the GFX100s. I can rotate the Mode Dial to change recipes, or I can access the "Q" button to review the recipe name until I memorize it or make changes. Is there any other alternative ways to access these Custom Modes (C1-C6), or to make their names appear on one of the available LCDs? Thank you very much.
    • GRACKLE!  70-300 at 300mm, xt5.
    • Practicing handheld shots, panning with slower shutter speeds to show motion and still freeze the subject details...........I got these down to 1/20 and 1/15 sec, 150-600 at 150mm, xt5.  Fun to try.
    • Trap Pond State Park, DE.......cypress trees on a calm day.  16-80mm.
    • Hello,   I was searching the video settings for X-S20 and the different bit rate options, and was wondering how can i calculate the minimum bitrate to use for a specific video configuration. For example how many mbps do i need for 6K open gate 30fps 4:2:0 H265 LongGop FLOG2 video? Does FLOG2 need more bitrate compared with normal video? Is there a formula you can use to calculate the minimum requirement?   Thanks!
