My studio work involves simple lighting setups—usually no more than two lights. For a couple of years I've been using Yongnuo RF-603C triggers (one on the camera, and the other on the Einstein). I usually use a Canon DSLR in the studio. This setup has worked fine.
I'd like to try transitioning to the X-Pro2 in the studio, but my first efforts ran into a major snag: the X-Pro2 hotshoe isn't sending a signal to the trigger. (Camera set to sync speed, and I ran through all the flash options in the Menu, etc.)
This appears to be a communications issue with the Yongnuo, because if I attached a speedlight to the X-Pro2, the speedlight will fire. (Likewise, if I run a PC cable from the socket on the X-Pro2 to the strobe it will fire. If I run a PC cable from the camera socket to the Yongnuo, tripping the shutter doesn't signal the Yongnuo.)
I'm wondering if anyone else has encountered this issue. Alternatively, I'd be interested in knowing what radio triggers are being used successfully with the X-Pro2.
Thanks!
Edited by James Conley
Thanks much for the replies. I'll look into the Cactus.
My concern is that there may be an issue with the hotshoe. I know the triggers I have work on the Canon. They just don't work on the X-Pro2. Which leads to the question "why." Could be that the power from the X-Pro2 hotshoe is less than what the Yongnuo needs, or it could be the post arrangement, or it could be . . . . etc. I hate to buy new triggers without knowing, but it's looking like that's what I'll have to do to narrow down the cause.
--J
The Cactus trigger/receiver works great and Cactus speed lights have built-in receivers.
Are you using the V6? Seems to be a bit pricey at $106 on Amazon. [Apparently only $70 at B&H] The PocketWizard Plus X two pack is $170.
I'm using Yongnuo flashes and triggers.  I don't think I've tried to max the sync speed yet, but I've had no issues with them firing using them from about 1/160 and slower.
I am using the NIKON versions of the 603 triggers as well as sometimes their controller that adjusts the power/zoom of the flashes.
So I wonder if it's some issue between the Canon version or if your hotshoe is just defective???
Interesting. I was quite worried it was a hotshoe issue, but I've racked up about 900 studio exposures with two different strobes and two different Radiopopper receivers without a single misfire. My best guess is that the power output on the hotshoe is not enough for the Yongnuo, because they work fine with a Canon body.
I don't know the difference between the Canon and Nikon versions of the Yongnuo. Since they're just tripping the strobe and not doing any TTL work, I'd assume they're only getting a signal from the middle, largest contact on the hotshoe. But it's possible that the pin pattern on the 603C is just something the Fuji doesn't like.
I usually have about a 1-2% misfire rate with the Yongnuos on the Canon. None at all so far with the Radiopoppers.
I prefer to use the Godox X1T N(ikon) version for my Godox Witstro flashes. This has never failed me at 1/250 and below.
Yongnuo YN560-TX also works fine with the Youngnuo 560 IV speedlights
So, no problems with these triggers.
  • 9 years later...
X100vi
Godox xpro trigger
godox v1 flash
the test button on the trigger fires the flash. The camera seems to see the trigger attached and on, but the camera doesn’t fire the flash. Is it a setting or is there something wrong with my camera? I was at a workshop and borrowed a pocket wizard that worked with my Nikon, but not with the Fuji.
    • I never knew the X70 existed! Looks interesting.
    • Equipment: Fujiflim X-M5 (firmware V 1.10). iPhone 15 pro (26.1) I am unable to properly connect my Fujifilm X-M5 to XApp on my iPhone 15 Pro. This setup previously worked without issues, but now the app only supports a basic remote shutter and no longer allows Get or Take mode, which are required for remote parameter control and shooting. I have repeatedly Initialized “FUJIFILM XApp”, re-paired the camera, reset wireless settings, and confirmed the camera is not in airplane mode, with both devices placed next to each other. None of these steps resolved the issue. Also, I am unable to update the camera firmware, as the process always fails with a “connection failed” message. I need clarification on whether this is a known firmware or compatibility issue and what the actual solution is.
    • Last day of autumn 2025. Autumn is gradual. Summer field crops slowly ripening. Cool, longer nights turn into morning fogs. Color (colour) touches here and there taking the place of flowers now resting until Spring. Then, after that slow introduction, Fall is everywhere. Winter is brash, Winter is not at all subtle. Freezing cold days and colder nights. The Sun struggles to get above the horizon. Bare fields, iced over streams and woe (‘Woe!! I say!’) to trees or shrubs holding onto leaves.
        But there is sledding, skiing and hot chocolate for those that like those things 😀.
      Winter is coming.
    • For some reason, the EV dial setting does not correlate to the EV setting displayed in the viewfinder.  My XT2 used to have parity between settings such that when the dial was at "0", the viewfinder also showed "0".  Has anybody else noticed this?  I've tried a reset of the s/w but no luck.
