Having tested & used ALL Fuji X lenses, the 16mm is their absolute best
figures one of the LAST lenses i test turns out to be the best Fuji X lens they have.
by "BEST" this ignores personal NEEDS / WANTS.... (wide zooms, portrait lens, tele lenses etc etc).
meaning, if you needed / wanted ALL Fuji lenses, which, regardless of its MAIN USE, ....is their BEST LENS
