xpro 1, 2 +16mm landscape photography and Lee filters.
Hello
Can anyone share experience with lee filters on x pro 1, 2
which version of the lee system do you own? Are there any OVF view restrictions?
or do you use screw in filters only.
I'm interested in Grad filters, ND, Polarizer
Well, you are clearly going to see the filter holder in front of the OvF, even the 18-55 lens kit protrudes into the OvF on the X-Pro2, which I find rather annoying. Hence the EvF in that case.
As personal choice, I dislike the screw on filters, it forces me to buy several of them while the holder can have several rings for my need and cost a LOT cheaper. Plus side, if you ever decide to change system, your holder kit system can still be used. Not so plus side, it's a bit annoying to use in a rush, then again if you are doing long exposure in a rush, you better not do it at all.
Do keep in mind I am speaking from a still photography perspective, if you are filming, the screw on filter is invaluable as time saver and practicability.
Hello
I DO NOT RECOMMEND X-PRO2 FOR THIS TYPE PHOTOS. IT HAS HOT PIXEL ISSUES.
    • Is there a way to keep your menu selection on the last option you used? For example.  When I select MENU the cursor defaults to MY Menu.  I scroll up to IQ settings, make a change, and return to shooting. When I press the MENU button again the cursor is back to MY Menu.  I really want it to stay on the IQ setting I was last using (or any other Menu setting). It's a PITA to keep scrolling up and down, back to the previous setting.  (Note.  My Canon Menu retains the position of the last option I was using). Thanks in advance for any help.
    • Im not partal to any brad, just opted to try these based on apparent price / performance.  I'm always looking for best bang per buck, hence Fuji I guess - haha Reliabilty does not concern me, as I always shoot to two cards for pro work (and burst shooting is not a part of that). Made sense for me to get the cheapest / fastest CF cards for hobby shooting.     I just got a Sabrent Rocket V60 512GB cheep (as the back-up card).   As long as neither of these freeze the camera I hope its a cheep solution for my needs. (AB AV Pro SE 512Gb and Sabrent Rocket V60 512GB).  Half a gig of redunat storge for $200USD is something I can live with. (Especially considering I can bust the hell out of the Anglebird). Cheers, Tomek
    • Would using an external charger be of benefit to the batteries life? I appreace it can be faster, but I doin't mind pluging in the camera over USB to charge. Does charging via the camera do as good a job as lets say the fuji's own external charger? Does the camera stop charging once the battry is full and not over charge? I couldn't find these deatails in these forums or in the manual. Thank you!   Image below shot on X-T2 in a sunny studio.
