I am trying to decide which of the two kit zooms to get with the X-T10, the premium 16-55mm or the less expensive and smaller 18-55mm. According the the specs, the 16-55mm is twice as heavy as the 18-55mm: with the small body of the X-T10, I wonder if the larger lens would over balance the camera.
I'm not too worried about the 18-55mm being a stop slower on the long end, nor its lack of weather resistance; but has anyone compared the image quality (and for that matter, the build quality) of these two lenses?
Thanks very much.
Rodger Kingston
There have been comparison made already
http://www.fujivsfuji.com/16-55mm-f2pt8-vs-18-55mm-f2pt8-4-vs-18-135mm-f3pt5-5pt6/
If one is not absolutely in need of the minor advantages of the more expensive and heavier zoom one shouldn’t discard the humble 18-55mm.
This lens is offered at a pittance in kit form with many X cameras and can be even cheaper if bought secondhand because there are tons of them out there for sale.
Unless you REALLY need that extra stop of light and some slight sharpness at the edges, I would pick the 18-55 over the 16-55.
I can live with that stop less of light at the far end but having to carry extra weight can be really annoying really fast. Plus I am super spoiled by the OIS from my 18-135 and I would hate to lose that on "standard zoom range" lens.
If you don't think you need the extra stop of light, I'd go with the 18-55. I'm sure the 16-55 is better in some ways, but the 18-55 has impressed me. Normally kit lenses are the first thing I sell or sit on the shelf. I think the 18-55mm beats the 24-105mm F/4L that came with my Canon. I like the smallness and lightness of the Fuji cameras and lenses. The 16-55 goes against that some but serves its purpose.
16-55 is mainly for pros who need WR and use tripods for stability. It is noticeably bigger, heavier, and no OIS. It's also more $. It is not that much better if u get a still shot but the cons outweigh the pros.
You will do much better with the 18-55 and primes. 18-55 will be more usable on the small grip xt10. And F1.2-1.4 primes will give you the true bokeh that you need.  OIS will help you get sharper shots without tripods.
A grip enlarger/extender will help on the XT10 regardless of which zoom u get.
    • Hey everyone, I am new to the fujifilm system, and I just received my X100vi about 15 days ago, and yesterday I noticed that ISO and exposure dials are acting up. I spent hours watching YouTube videos and reading forms without finding any solutions. Using ChatGPT or Gemini also didn’t help. My issues are the following: If I want to set my ISO at a specific value then the camera LCD/EVF shows a totally different value. For example, I have shutter manual, aperture manual and ISO dial at 6400, the camera shows ISO at 4000, when I take pictures it will show ISO at 4000 and not 6400. When I try to choose another ISO value it will skip some of the available values that are shown on the dial. Another issue I am having is when my exposure dial is not set at specific value, then I cannot set ISO to Auto no matter what value I select on the dial. If I do select the different exposure compensation values, then I choose A for ISO, the camera will activate the front commend dial to manually change ISO values. To get in Auto ISO, the shutter speed cannot be set in auto and the ISO dial should be set at 125, when I turn the ISO wheel, it seems like the numbers are misaligned by one value, If I put the dial on A with shutter speed manual, then it will trigger the front commend dial. The other issue that I am having is when I have Aperture, shutter speed and ISO on manual, If I change the exposure dial compensation + or - , it actually changes the exposure of the picture as well as the ISO value, which as I understand, if Camera is in full manual, the exposure dial should do nothing. The last issue that I am having, if I do have ISO in manual at a set value, and adjust exposure compensation dial, it alters my ISO instead of my shutter speed or my aperture, even though ISO is in Manual and the other two dials are in Automatic. I am not really sure if all of this is by design and I am just not understanding how everything works together, but it seems really odd how everything changes. Resetting the camera settings didn’t help.
