Other than protecting the glass,  since exposures can be manipulated in camera and with post processing,  is there any benefit/difference in using a UV filter vs ND filters? Any brand recommendations?   I have read up and googled this question but just wonder how helpful it is in digital cameras.  Thanks.  Norm
Exposures can certainly be manipulated in camera but only an ND filter will allow control of the aperture/shutter speed for a given amount of light. Only an ND filter will allow you to reduce the overall light level so that a specified aperture/shutter speed combination is possible. But I would never keep an ND filter on my lens as it is often not appropriate to want to reduce the light level.
As for using a UV or Clear filter on your lens, a UV filter is only of use in analogue photography where it was often necessary because film is extremely sensitive to UV light. However, digital sensors are generally rather insensitive to UV, so the problem doesn't arise to anything like the same extent. So if you are looking to simply protect your lens then either will do but my choice would be a Clear. I know there is a body of opinion that says using any protection filter impacts on the quality of the result but I've never noticed it and I'd rather replace a filter than my lens.
There are probably only 2 filters which cannot be replicated in post-processing - the ND as above and the Polarising filter.
Note that manufacturers usually don’t advertise with filters being a ‘lens protection’. This is because of liability issues. A clear or UV filter protects lenses from dust, watermarks, fingerprints and light scratches. Most damage to front elements comes from ‘cleaning’  the lens by the user so a filter definitely helps here. But don’t think that a filter helps against impact damages. In fact, the filter thread may even cause more (deformation) damage to the lens. Brass filter rings usually hold better under impact damage.
Modern sensors don’t care for UV filters unless you’re in very bright conditions (high in the mountains or Antarctica).
Indeed the only filters that cannot be emulated in post are ND and Polarising filters. However, note that emulating in post sometimes gives artificial effects. That’s why many landscape photographers prefer physical gradient filters to better control the effect.
i have the best experience with B+W and Hoya filters. They have very high and consistent quality. Cokin makes some good filters as well (their Pure line). Best avoid cheap nameless filters. When you buy a variable ND filter, make sure its a very good one (usually these are expensive). The lesser ones give a purple color cast when ‘closed’. Alternatives are of course the filter systems of Lee, Benro, Rollei, Cokin, Nissin et cetera. Those are usually used in combination with a tripod and not designed for walking-around.
    • Hi I am just following the lead to introduce myself. I go by the name Wild Goose. Strictly I am not a newbie, I have been on this site before when I owned X100F and XT2 but I would like to start again. I committed a heinous crime and drifted into another camera brand for a while, so I left this forum. However, I love Fuji too much and I have sold all the non Fuji gear and am awaiting the arrival of the new X.E5.  I feel it might be a ‘Marmite’ camera (love/hate) but I think for now, I love it. To me it is the best of the X100F with interchangeable lenses.  I cannot wait to get back to using Fuji again. I trained in the photo industry and have boring old qualifications that mean very little in this digital world. I first worked as a black and white printer and later as a photographer, press and commercial. I even have a Kodak award for my time as an assistant photographer but those days are long gone. I have been out of the industry for a few decades, so those days are distant memories and I am a true enthusiast.  I am happy to chat photography with others, although I am not highly technical, I was back in the day when I was printing etc, I am more artistic now and enjoy the creativity that Fuji gives me over other brands. I recall days of shooting bluebells with Velvia trying the capture the right colour compared to ektachrome and I am looking forward to switching the ‘films’ on 5 and seeing what that gives me. Cheers  WG
    • hi, I'm about to buy either the X-E4 or the X-E5 model, but I find the viewfinder to be quite small, especially for manual focusing, which I plan to use. Do you know any third-party accessories that could be attached to the eyecap to magnify the viewfinder field? Thanks!
    • Hello, I currently use a Canon EOS R5 for architectural photography. I'm considering switching to a Fujifilm GFX100S II. Are there any disadvantages I should be aware of? (Apart from there being only one Fujifilm tilt-shift lens currently.) Thomas
    • I had a feelworld connected to the xh2s and it was working beautifully. I was using a USB-A to USB-C cable to power the feelworld monitor. Then I switched to a Dtap to 12v cable. And now the whole camera becomes inoperable when I try to connect through HDMI. I even bought a new HDMI cable cause I read somewhere that a 2.0 hdmi cable may fix the problem, but that did not work. Reset the camera to default, did not work. I feel like I tried every menu setting on both the camera and monitor too...HELP PLEEEASE. This issue is super annoying, that it was working and now it's not. For a nearly 3000$ camera, its sad this kinda issue is occurring.
    • I hope you are able to get this working in your favor. As a bonus, the card readers mostly are faster and easier ways to move images from the camera to the computer.
