Gimbal
I own a Ronin SC. Compatibility with my XT-30 similar to if it was a brick. Anyway I see no issues, Ronin SC works well as a gimbal without a specific DJI features. I start and stop filming pushing a button on a camera. Focus wheel works well with all my lenses.
So there is no compability at all?
There is a compatibility using a special cable. But as far as I understood it will only add a start/stop record button usage on a gimbal, but not a specific DJI features. For me gimbal is gimbal, and Ronin works well as a gimbal. Tracking and other ‘cinematic’ features I can use on my DJI Osmo pocket, for a serious things I use my hands and brain.
