Using PC Autosafe with my camera
rogchow
Hi
I have downloaded PC Autosave on my MAC, running Catalina. I have also setup the camera following the instructions to connect my X-T1 to the computer wifi network. The PC autosave is configured with my Camera based the setting. However, when I launch the camera wifi, it will not connect to my PC. The default device which is my iPad is shown there and I choose the "change" option but my PC would not show up. By the way, the connection use my home network and I did not connect my PC to the camera SSID(which I usually do when I use my iPhone or Ipad).
Can somebody help me with this please?
Much appreciated.
