Troubleshooting 4x5 view camera adapter focus
Hello! New here and looking for some help. I recently purchased the view camera adapter g for use with my Cambo legend 4x5 camera, using a 135mm Schneider 5.6 lens. I have done everything I can think of and cannot get it to infinity focus. It will only focus on a very close object. Ruled out the camera and lens as I get perfect focus on the ground glass. Given that the sensor is far from the ground glass, read that it could be corrected with a recessed lens board. I tried this and there was no change in the focal length so thinking the lens and focal length is not the issue. I’ve seen others use this adapter successfully online so I think there must be a solution. Can anybody help? If you’ve been successful what settings on your camera did you use?
