if you're talking about the focus point selection then what I do is either half press the shutter or press the menu button and it goes away.
check your function buttons for the af selection and make sure that you're not pressing that fn button by accident.  keep in mind that there's one on the front that you can accidentally press and if you have the batter grip there's another on the bottom side of the batter grip that the heel of my hand keeps hitting.
Edited by roicead
Hi Mike
Not sure if this is what you want or is just a half measure.
1. Dont press the toggle button in when manipulating it. In this state you only get very small dots on the screen.
2. When you press the toggle in. the hard squared grid appears.
3. To get it back to just the pin dots on screen, press the menu button.
Hope that helps
