  • 9 months later...
I try to turn off IS whenever I'm on a tripod with ALL my Fuji's.  That is: when I remember.  However, when I do not I honestly can't tell the difference.  But, I'm sure if I were to make a 40 x 30 print from my 50R there "may" be a subtle difference?  Maybe?  I always say better safe than sorry.  Look, you went through all the expense of getting the equipment, traveling to a location, and the time to be there and capture the image you've always wanted.  Why not play it safe?  As I said I try to, but I do forget at times and have not noticed any difference in prints up to 20 x 20" so far.
