We're going to start the big forum update next week (Monday or Tuesday), as all tests went well…
We'll have a short downtime (for backup and migration) and a phase of some hours in which you can use the forum without some content in perfect shape...
So wish me luck and look forward to the new Fuji X Forum!
Andreas
