Hello bhedges. Yes, that is a silly option by Fuji in my opinion. Right now I don't remember well, but they could have specified in the manual a different way like "shoot with a manual lens" rather then "take a photo without lens".
There also should be something connected with the sound. But I might remember wrongly.
