Two manual lenses and X-T1
adrian22
Hi,
I have Samyang 12mm and I'm planning to buy another manual lens.
In Mount Adapter Settings there is option to select focal length of the lens. For Samyang I simply set it to 12mm and forgot.
The question is if I have to change it every time I change lens on another manual one? Does x-t1 add some correction based on that parameter? Or it is there only for adding information to exif data?
I'm shooting only in RAWs.
Thanks
Adrian
You have to change it for every lens you mount on the camera.  That is why I wish Fuji would allow that setting to be added to the Q Menu !!!!!
The value you enter does nothing to correct the image due to any possible lens distortion.  It is only adding that focal length to the EXIF data.
Have fun shooting with vintage adapted lenses.  :)
    • Welcome to our forum 😊
    • After 20 years with Canon (EOS100, 300D, 5D2, 7D2) I ditched everything and moved to Fuji XH2S a year and a half ago. I had been holding out for a mirrorless 7D2 but was disappointed when the R7 was released and realised that the XH2S was actually what the R7 should have been, and Fuji seem to be the only company taking APSC seriously.  It also felt like Canon were pricing themselves out of the enthusiast market (£120 for a battery, come on!). Blocking third party lenses was the final straw for me as most of my lenses had been Sigma. Anyway, I haven't looked back since. Is the XH2S perfect? No, but everything is a compromise and this gives me the best functionality/weight/price balance for what I do. I shoot mainly wildlife and landscapes but occasionally other stuff like local events, all just for fun.
    • So I ended up getting and X-H2 over the X-T5 because of a good deal that came up.  Needing to buy a card, I needed to figure out,  what is the real impact of a card's speed for photos?   In particular, I'm going to test how shooting at 15 FPS will differ between: Angelbird - AV PRO CFexpress B SE - 512 GB and Angelbird AV PRO CFexpress SX - 160 GB. How many shots can I get off before buffer fills, and how long does it take for the buffer to clear?    MOP: X-H2 Factory rest, card formated, no lens (body cap on), performance boost on, manual exposure, mechanical SS @ 1/8000, IS off, Shoting RAW Compressed Lossless with only one card in. Held shutter release till buffer filled, and used stop watch to see how long for buffer to clear. Subtracted two frames from total taken as that's how long it takes me to release the trigger once the buffer is full. Repeat 2x for sanity check.   ***TEST RESULTS***   ~~~64GB Lexar Pro SD 150MB/s~~~ 75 shots to fill buffer, 36 Seconds to clear it   ~~~Angelbird AV Pro SX 160GB~~~ 251 shots to fill buffer, 5 Seconds to clear it   .~~~Angelbird AV Pro SE 512GB~~~ 232 shots to fill buffer, 4 Seconds to clear it     ***Conculsion***   If burst shooting an X-H2 at 15 FPS is your thing, buy the Anglebird 512GB SE for the same price as the 160GB SX.   Below is a shot on X-T2 w/ the Fuji 70-300. I manged to fluke it off with a dead battery by turning the camera off and on again, and squeezing three more shots out (this was the last shot).   Ta for now!
    • Xt5 firmware updated and now cannot see pics taken on lcd when pressing playback. Any ideas please? Elie
