How are you using the advanced filters on the drive dial? They seem to me to be a feature that is using up valuable space on a camera control that would be better in a menu. Having direct access to something like turning on the self timer would be more useful on the drive dial. Anyone making good use of the advanced filters feature?
What advanced filters?
+1
Good idea. I suppose most people seldom use them, neither do I.
in some cameras they are under a menu.
I don’t mind to have them where they are in my X-T1 and yes, they are not much used the main reason being that it is not possible to shoot with them whilst shooting raw as well ( which I believe would be a real game changer in the use of these “ special effects” since you will have a back up without the effect).
jpg+raw while shooting with effects: good idea too. Also, I would like the camera to shoot in jpg+raw while in auto mode - you put the camera into auto mode and hand it to someone to take a picture and you forget to move the exp. comp. dial back from your previous shot or the conditions are not ideal - the raw would come in handy.
yes, these days everyone feels that everything should be personalized to one’s taste or needs (whether they are real needs is a different thing).
I take a realist view to all of this and think that it will come to fruition if it possible at some stage, in the meantime I adapt and use what’s available within the limitations (mine or the equipment).
I will reword the question - what would be better on the drive dial than the advanced filters? I believe this should be for features that a significant number of users use regularly. Enabling self timer is one I would use a lot - I turn it on every time I use the tripod, having a filter for a black and white view would be more useful than the options provided. Anything else?
Edited by NHKeith
Makes sense to me, it was much easier to trip the timer in order to avoid camera shake on most cameras - even by means of a lever - than it is on most modern models
Edited by CDBC
    • I just want to say thanks very much!  That worked a treat - did as said used ‘clean all’ command and then waiting a while for it to do its thing, once I put the card back into the camera and initialised then removed it and put it back onto the PC it worked and popped up as usual.  Somehow overtime all 3 of my cards must have become corrupted.  But doing this worked, again Many thanks  Here are the steps I took so that if anyone else runs into this issue they can fix it: 1.  Put express card into the reader and plug into pc (you should hear a sound, but the card will not mount).   2.  Run ‘Command Prompt’ as an administrator,  you can find it in Start Menu and right click then run as administrator.  3. type in ‘diskpart’ This will load the software, be careful here as you could accidentally format the wrong drive. 4.  when DISKPART> is displayed type ‘list disk’.   wait a while and a list of all disks on the system will appear, look for the disk that is the size, in my case it was 476GB.  double check this is the right disk as you will format and erase all content on this disk to make it work.  5.  type ‘select disk 3’  in my case disk number 3 was the right one. 6.  type ‘clean all’   it took mine about 15 mins to work, it looks like it is doing nothing but it isn’t, it’s doing a full format.  You will get a prompt ‘DiskPart succeeded in cleaning the disk’ 7.  Remove the disk and place back into fuji camera, then format/initialise as normal.  8.  eject disk and place back into PC and it should mount as usual.   Hopefully that works!
    • I haven't had any problem with my XH2s and CFexpress card, but I struggled for almost 1 year with a 256GB SD card . To cut it short : I finally solved the problem formatting the SD card using windows DiskPart command. I think the key was removing everyting from the SD card using the "clean" command. Diskpart is rather technical, I hope you can understand how to use it. Search google for :   "diskpart erase partitions" Hope this helps.
    • Hi,  i’ve had a look around the internet and can’t seem to find anyone with this issue.  Long story short is I used to be able to access my CF Express type B cards that are formatted by my XH2s on my pc and my mac.  They would pop up as an external drive through an external Sabrient reader.  Now they don’t?!  Has something changed in the firmware? something broken. A few observations: It now happens with all of my Sabrient cards. I bought a new Lexar reader and it does it with that too. If i format the cards on my RED camera and then mount on the computer they work fine as expected.  Once I put back in camera and format the card then place back to PC it doesn’t work. The only way i’ve been able to access the card is while it is plugged into the camera but this seems a lot slower to transfer data. Has anyone else noticed this? would appreciate any solutions.
    • Replied with samples on a different forum
