I'm wanting to use my new XT2 for meteor photography - taking a series of 20sec exposures over several hours at night. To ensure I don't have to keep replacing batteries throughout the night, I have bought an external power source which powers a dummy battery, replacing the original battery.
My question relates to closure of the battery door.  I have lifted the small plastic plug, with long nose pliers, which is attached to a rubber strip. The cable, leading from the dummy battery, fits through a round aperture in the plastic plug.  The plug can then be pushed to one side, via the rubber strip, to allow the battery door to close.
This looks to be the way it works but I can find nothing in the instructions, or on the internet, to confirm this.  Can any one confirm I have it right. I don't want to damage the camera!  Many thanks.
Tony
I don't know about the X-T2, but in the X-T20 manual there's a documented "Cable channel cover for DC coupler" -- see part #36.
http://fujifilm-dsc.com/en/manual/x-t20/about_this_camera/parts/index.html
It's a rectangular section on the right edge of the battery cover.
I know on the X-T1, you had to have the battery grip to use the DC coupler. In reading about the X-T2 battery grip, it sounds like you'd simply use that instead of the separate power unit. From what I can tell, if you have the charging cord plugged into the grip and then turn on the X-T2, the camera is powered but the grip isn't charged.
Edited by Doug Pardee
Thanks for those comments, guys.  I did think of buying the battery grip but didn't want to add weight and expense.
I'm really surprised there is no mention by Fuji in any of its documents about this small plastic plug which, now, I find I can lift with a finger nail.  I've used the dummy battery a few times in recent days.  It's very useful to have a power source equivalent to 10/12 batteries!  I don't think the battery door pinches the cable leading out of the dummy battery.  The only reference I can find to using a dummy battery is in this link...https://www.fujix-forum.com/threads/fujifilm-ac-9v-ac-power-adapter-how-to-use.32973/
Two posters actually refer to leaving the battery door open.  Surely I'm not the only one who's discovered the 'small plastic plug' and what Fuji presumably has designed it for!
    • Example: I am using a custom recipe, and I then use the film simulation dial to select a simulation. Are values from the custom recipe carried over, such as highlights, shadow, and white balance etc.? After studying the articles in Fuji X Weekly, this appears to be the case If you set a recipe on one of the C slots its settings will be applied to all the film simulations on the dial. The workaround is to use your 'standard' recipe at C1.   Please clarify this for me . I would have thought the film simulation dial would have no input from other camera settings.   Thank you - Very Confuded!
    • Is this on the X-T30 II? Sounds like you have HDR selected in the shooting menu. The other alternative when you see the "storing" message is that the Clarity setting is non-zero but that doesn't cause multiple clicks.
    • My XS10 came with a Capture One license but my PC at the time would barely run it so I stuck with my ancient version of Picasa.  Bought a new PC and my old Capture One has been deprecated and fuji site only talks about a 3 month trial.  Is there a work around or should I be looking for something else?
    • On aperture priority and single shot, camera clicks twice after one shot and then takes several seconds showing "storing" message.  This is a new camera and did not do this at first.  Does not do this on auto.
    • I have the Fuji 80 mm macro and really like it. It's very sharp and I use it for macro but also for general photography. If you find yourself zoomed to 55, this may land in the right spot. Also, this lens is very good with magnification distortion (pincushion or barrel), which is probably important if you're doing product photography and the product has straight lines. It is autofocus. I hear you don't prioritize that, but there's something else you gain when you have autofocus. You can combine multiple photos taken at slightly different focus distances, using stacking software, and autofocus lets the camera automate the process of taking all these, using focus bracketing. It even calculates how much the focus should change between these exposures. This lens, new, is above your stated budget. Maybe you can find it used? In any case, options are always nice to have, and others may like this option too. So, just a thought. One more thing: I've never used the Laowa macro you mention, but I do have their circular fisheye. I love circular fisheyes, and also have two other brands, and comparing them I find the Laowa is considerably better than the other two. That's a vote for Laowa.
