Pixel shift combiner can't open folder in win11
Is the X-H2S “dynamic range improvement” a myth? Since the release of the Fujifilm X-H2S, Fuji has heavily promoted: the sensor’s internal 14-bit readout, the new F-Log2 profile, and a supposedly tangible improvement in video dynamic range compared to previous generations (X-T4, X-S20, etc.). But when you look at actual laboratory measurements, the narrative starts to fall apart. What the numbers actually show (measured data, not marketing) Based on IMATEST / SNR-style measurements: X-H2S ≈ 12.2 stops at SNR=2 ≈ 13.6 stops at SNR=1 Measured in ProRes HQ, high native ISO (1250) X-T4 ≈ 11.8 stops at SNR=2 ≈ 13.4 stops at SNR=1 Measured in H.264 / H.265, lower native ISO (800) The real-world difference is about 0.2 to 0.4 stop, depending on the threshold used. This is nowhere near a generational leap. The core question: where did the 14-bit promise go? If the X-H2S sensor is truly read internally at 14-bit, a simple question arises: Why does this extra bit depth not translate into a measurable increase in usable dynamic range? Because: the final recorded signal is still 10-bit, read noise appears to cap the signal before those extra bits can matter, SNR curves remain very close to those of the X-T4. In short: 14-bit upstream, same ceiling downstream. And what about F-Log2? F-Log2 is supposed to: extend highlight latitude, better exploit the sensor signal. Yet in practice: measured dynamic range barely increases, what we mostly see is curve redistribution, not actual expansion, shadow noise rises earlier. This raises a legitimate concern: Are we just looking at a remapping of the same dynamic range, rather than a true physical gain? Provisional conclusion (but an uncomfortable one) Based on the available data: the X-H2S “dynamic range improvement” appears largely overstated, the 14-bit readout looks more like a theoretical talking point than a measurable benefit, F-Log2 seems primarily like a grading convenience, not a sensor-level breakthrough. Open but serious question Is the internal 14-bit sensor readout and F-Log2, in practice, a damp squib with no truly palpable impact on real-world video dynamic range? If anyone has: independent measurements showing otherwise, or a demonstrable gain beyond ~0.3 stop, I’m genuinely interested. But for now, the numbers simply do not support the narrative.Welcome, dear visitor! As registered member you'd see an image here…
By MARRIEDGUY9 · Posted
nothing special, I thought the sky looked cool, handheld, unedited, 16-80 around F11. Bay inland of Indian River, DE right after sunset.Welcome, dear visitor! As registered member you'd see an image here…
Hello everyone, Recently, I've come across the very detailed videos from Edvard (@edvard2942 on YouTube) about Fujifilm autofocus performance. His tests highlight what he sees as a regression in AF fluidity and reliability starting from certain firmware updates, and that the best results aren't always with the latest versions. I'd love to start a discussion here to compile, based on your experiences and Edvard's tests, a kind of “best firmware list”for each body in terms of autofocus smoothness and reliability (especially in photo and video AF-C with older lenses). Here's a summary of what's already well-established from Edvard's analyses (feel free to correct or add details): • X-T3 Firmwares 3.00 / 3.30 are considered the best – smoothest AF, most natural transitions, fastest and most frequent lens motor adjustments. From firmware 4.00 onward (the one that aligned it with the X-T4), there's a clear loss of fluidity in micro-adjustments and quick distance changes. • X-T4 The AF from the initial firmware (~1.00) already uses the algorithm introduced on the X-T3 with 4.00. It's less smooth than the X-T3 on 3.xx, but generally stable. Later updates did not restore the older X-T3 smoothness. • X-H2S Very early firmware (around 1.03) is significantly better than later ones (3.xx, 5.xx, 6.xx, 7.xx), which degraded fluidity. However, even this best version remains below the X-T3 on 3.xx in terms of pure AF smoothness. I'd really like us to expand this list with other bodies (X-H2, X-T5, X-H1, X-Pro3, etc.). Which firmware gives the best AF according to you, or according to the Edvard videos you've seen? One specific question that's bugging me: Can we expect early X-T4 bodies (with factory/original firmware) to be as smooth as the X-T3 on firmware 3.xx? Or is the difference already there from launch? Thanks in advance for your feedback, any downgrade experiences, and tests with different firmwares and lenses. This could help a lot of people optimize their setup. -
Bob is a well-known and much appreciated street performer, musician, comedian, and sometime circus performer. GFX100RF. 3200 ISO 1/60 sec. f4.
If the spots are in the same place every time then its likely a dirty sensor - you can buy a sensor cleaning kit and do it yourself or take it in to get cleaned professionally.
