Switched to XT2 late last year. XT1 was the camera that made me switched from Canon SLR to Fuji. I have not regretted my decision. Here is one of the last weddings we did with XT1 last year. I still don't get some of the latest reviews I've read that said the XT2 is not good enough for weddings. The XT1 was good enough for me!
http://binaryflips.com/blog/2017/01/laura-kyle-wedding-at-branford-house-ct/
  • 1 year later...
  • 5 months later...
Hi, I use the XT-1, X-Pro1 and the lenses 16-55mm f2.8, 55-200mm and the 35mm f2.0 .
Do you use primes or zooms for your work?
I would like to buy a XT-2, there is a cashback, so it will cost me less than 1000 euro. Is it worth buying or do I go (later) for the 1500 euro XT-3?
