Taken during a recent trip to China, Sichuan Province, Emei Shan - a buddhist place of pilgrimage - using my X100T.
Looks like a magical place. I particularly like the third shot. Were they all on their phones?
More importantly, did you go to Chengdu and did you visit the pandas :) ?
The monks were on phones but unfortunately I couldn't get that shot. I was in Chengdu - one of the more attractive Chinese cities - but missed the pandas.
I really like the processing done on those images, what software are you using?
Thanks for your comment. I tend to pass the raw files through irridient and then into lightroom for more detailed adjustments.
