  • 5 months later...
I have the same problem.
I have formatted the SD card, I download directly to the SD card (via a card reader), the file i get is called XFU0065.DAT, and it is setting in the root directory of the card with no other files there at all.
The message I get is Firmware not found in card slot 1 (I am using card slot 1). Nothing in card slot 2).
@Steve Kingswell did you ever figure out how to fix your issue? I have the 56mm 1.2 and have been trying to upgrade to firmware v1.01 and I keep getting that same "Firmware not found in card slot 1" message.
I tried downloading the file to my comp and putting it onto a freshly formatted SD card via a card reader, downloading it straight onto the card, etc.. nothing seems to work. I just upgraded my 16-55 just fine, worked right away, but the 56mm I just don't get it. ¯\_(ツ)_/
Edited by Jon Phillips
I have been having the same problem. I haven't been able to upgrade from 1.0. Last two upgrades gave me the same message. All other lenses updated, camera updated. I tried it over and over different ways and I cannot get the lens to update. This has also made my manual focus not work well.
Does anyone have an answer here? FUJI can you help us???
Here it is Oct 2023 and I'm interested in upgrading my firmware for my Fuji 56 1.2 lens.
I download the update from the Fuji site onto my SD card, put it in the camera, then get the message as above
"Firmware not found in card slot 1."
Has anyone figured out a fix for this, please and thank you.
ADDENDUM: Just discovered that this firmware update is for the 'WR' model which I don't have.  I didn't
know there was a newer model of this lens.  So, for the 'R' model, there doesn't seem to be an update for firmware
from v1.00.
Thank you,Patrick
