I currently have an XE2 with the 18-55mm and 10-24mm lenses. I'm going travelling soon and have just spotted that (in the UK) there's £150 cash back on the Fuji 18-135mm and I'm quite tempted to get it to give me more versatility on holiday. However, I'm a bit worried that it might be a big on the large side when paired with the XE2 - anybody got that set up and how do you find it as a carry around all day unit?
Thanks Maurice - interesting comparison. I'm not convinced yet - I wanted to have a system that was smaller and lighter than my full frame Nikon and that might be creeping back up in size too much again. I think I need to get to a shop to try it out in the hand.
Comparison with D610 and 28-300mm: http://camerasize.com/compact/#493.359,493.426,486.329,ha,t
