Hi guys,
As you probably know :-), there's no such thing as Flash White Balance setting in our X-T1s. When using a dedicated Fuji flash, the camera probably gets the info from it, acknowledges its presence and applies corrections.
Do you have any ideas how to force it (or which setting to use) to do it when using a 3rd party, non Fuji dedicated, flash? I have some Canon compatible TTL speedlights and they work well with Fuji (in full manual mode, of course), just the wretched WB is always off.
Any ideas?
TIA
If you're using your flash as main light source, you could use a gray card and the custom WB setting to set the correct white balance. If you're using it as fill flash, use gels to balance the output of your flash gun to the ambient light and set your camera for that.
rvhout - thank you, sir! I am aware of these possibilities, but I was hoping to find some "quick" solution. There's not always time for gray card or playing with gels, and I really could use such setting - just install your flash, set WB accordingly and shoot, just like "the rest of the photo world".
Why we can't have a Flash White Balance preset is really beyond me. Hell, we even have Underwater setting, but no Flash. I wonder what's the percentage of users doing underwater photography with their X-T1 vs. those using flashes / speedlights. Especially while Fuji's offer is non-existing when it comes to flashes.
Well, if you pre-set one of the custom white balance settings with flash and gray card once and use that as 'Flash WB', I think that's fairly close to what you want? Note that you don't need to recalibrate custom WB settings every time you select them, so it basically becomes a fixed preset until you set a new calibration.
Thanks, guys! Both advices true and useful. If I only knew what's the color temperature of my cheap (yet working surprisingly well) flash :-(
I think I need to go the gray card route and create a preset. I am still wondering how come I didn't think of it myself :-0
Anyway, I'd still trade the Underwater WB setting for Flash in a blink :-)
    • Hey everyone, I am new to the fujifilm system, and I just received my X100vi about 15 days ago, and yesterday I noticed that ISO and exposure dials are acting up. I spent hours watching YouTube videos and reading forms without finding any solutions. Using ChatGPT or Gemini also didn’t help. My issues are the following: If I want to set my ISO at a specific value then the camera LCD/EVF shows a totally different value. For example, I have shutter manual, aperture manual and ISO dial at 6400, the camera shows ISO at 4000, when I take pictures it will show ISO at 4000 and not 6400. When I try to choose another ISO value it will skip some of the available values that are shown on the dial. Another issue I am having is when my exposure dial is not set at specific value, then I cannot set ISO to Auto no matter what value I select on the dial. If I do select the different exposure compensation values, then I choose A for ISO, the camera will activate the front commend dial to manually change ISO values. To get in Auto ISO, the shutter speed cannot be set in auto and the ISO dial should be set at 125, when I turn the ISO wheel, it seems like the numbers are misaligned by one value, If I put the dial on A with shutter speed manual, then it will trigger the front commend dial. The other issue that I am having is when I have Aperture, shutter speed and ISO on manual, If I change the exposure dial compensation + or - , it actually changes the exposure of the picture as well as the ISO value, which as I understand, if Camera is in full manual, the exposure dial should do nothing. The last issue that I am having, if I do have ISO in manual at a set value, and adjust exposure compensation dial, it alters my ISO instead of my shutter speed or my aperture, even though ISO is in Manual and the other two dials are in Automatic. I am not really sure if all of this is by design and I am just not understanding how everything works together, but it seems really odd how everything changes. Resetting the camera settings didn’t help.
