(I know this shot/editing is ugly but I was too lazy to make it better)
Hey guys it's me again with another lens comparison test. Did a different one before: http://www.fuji-x-forum.com/topic/317-135mm-lens-comparison/
This time I compared three different 18mm lenses Fuji is offering.
XF 18mm f/2 (X-E2)
X70's 18,5mm f/2.8
XF 18-55mm f/2.8-4 (X-E2)
The shots are unedited (fine L) Jpegs (SOOC). I just cropped them and stitched them together. The settings of each camera were set to default (0) except the WB (I adjust it manually with a white peace of paper). ISO 200. Provia. Aperture priority.
Cause I don't have a tripod that's so low I used a chair where I put the cameras on top so the frame can vary a bit. Sorry for that.
Click on each pictures to open and maybe download on Flickr in full resolution.
If you have any questions please ask. If you have any complaints about my test please be polite within your criticism. I'm not a pro so this test might be far away from being perfect.
Feel free to share some shots/comparisons of your 18mm Fuji lenses.
So now I hope you will enjoy my little CD collection ;)
(the second and the forth fifth of this rack are covered by a glass door)
f/2 center
f/2.8 center
f/4 center
f/5.6 center
f/8 center
f/11 center
f/16 center
f/22 center
Take a look at the f/2.8 image. The black box with the white letters on it, in the top right corner of the crops. The 18 2.0 is unsharp, the other two are not.
When you see this, you'll notice more differences (e.g. the big grey box, "2 Originals of Something").
Is it just me? I do not see real differences. Some expert out there who can does?
looking at images on flickr at f/2.8 the difference seem slight to me,
Suprisingly that was my first impression too. I think it just shows how good all Fuji lenses are. I will do some different tests especially between the X70 and the XF18F2. My first impression of the X70 was: Oh damn is this little thing sharp!!! But after I did this test I was kinda "shocked" that it actually doesn't perform (much) better.
    • Hey everyone, I am new to the fujifilm system, and I just received my X100vi about 15 days ago, and yesterday I noticed that ISO and exposure dials are acting up. I spent hours watching YouTube videos and reading forms without finding any solutions. Using ChatGPT or Gemini also didn’t help. My issues are the following: If I want to set my ISO at a specific value then the camera LCD/EVF shows a totally different value. For example, I have shutter manual, aperture manual and ISO dial at 6400, the camera shows ISO at 4000, when I take pictures it will show ISO at 4000 and not 6400. When I try to choose another ISO value it will skip some of the available values that are shown on the dial. Another issue I am having is when my exposure dial is not set at specific value, then I cannot set ISO to Auto no matter what value I select on the dial. If I do select the different exposure compensation values, then I choose A for ISO, the camera will activate the front commend dial to manually change ISO values. To get in Auto ISO, the shutter speed cannot be set in auto and the ISO dial should be set at 125, when I turn the ISO wheel, it seems like the numbers are misaligned by one value, If I put the dial on A with shutter speed manual, then it will trigger the front commend dial. The other issue that I am having is when I have Aperture, shutter speed and ISO on manual, If I change the exposure dial compensation + or - , it actually changes the exposure of the picture as well as the ISO value, which as I understand, if Camera is in full manual, the exposure dial should do nothing. The last issue that I am having, if I do have ISO in manual at a set value, and adjust exposure compensation dial, it alters my ISO instead of my shutter speed or my aperture, even though ISO is in Manual and the other two dials are in Automatic. I am not really sure if all of this is by design and I am just not understanding how everything works together, but it seems really odd how everything changes. Resetting the camera settings didn’t help.
