Your best setting and film mode for nightshot
mano76
First of all, all those settings are only (mostly ?) applied to the jpeg output files.
If you shoot RAW files, none of the above matters.
And if you shoot jpeg directly, there are no one settings for all. You will need to change them on regular basis depending on your subject. Sometimes you will have more light, other times you want to keep the reflection on water (think of port cities).
What I usually have is have the NR at 0 or -1 and Sharpening at around 0 or +1 depending on how bad it looks from the LCD.
As for film simulation, I like Provia a lot but if there are a lot of colors and I want deeper night too, I swap to Velvia.
Little side note, on the bracketing option, you can go for Film Simulation, just pick 3 of them that you like/want to try and take the shot. You will be rewarded with 3 jpeg files with each their own film simulation, kind of handy if you are unsure which one would come out the best for the scenery.
Yeah, low NR, although I do use Long Exposure NR (black frame NR). Definitely go with raw+Fine. Fine so that you can gauge your shots in camera and raw to have all the latitude the raw file allows for later. Use low ISO (200) and small aperture (I prefer 11 +/1 one stop).
Get a good tripod. Get a cheap cable remote release, you can't go beyond 30 seconds without one. Rest of the settings don't matter too much. Learn how to operate full manual to get the most out of it.
It's really not hard, go out and shoot some, take a look at the results, go out again and repeat with the experience from last time. It takes a few times to get some nice shots, but it's a lot of fun.
    • Welcome to our forum 😊
    • After 20 years with Canon (EOS100, 300D, 5D2, 7D2) I ditched everything and moved to Fuji XH2S a year and a half ago. I had been holding out for a mirrorless 7D2 but was disappointed when the R7 was released and realised that the XH2S was actually what the R7 should have been, and Fuji seem to be the only company taking APSC seriously.  It also felt like Canon were pricing themselves out of the enthusiast market (£120 for a battery, come on!). Blocking third party lenses was the final straw for me as most of my lenses had been Sigma. Anyway, I haven't looked back since. Is the XH2S perfect? No, but everything is a compromise and this gives me the best functionality/weight/price balance for what I do. I shoot mainly wildlife and landscapes but occasionally other stuff like local events, all just for fun.
    • So I ended up getting and X-H2 over the X-T5 because of a good deal that came up.  Needing to buy a card, I needed to figure out,  what is the real impact of a card's speed for photos?   In particular, I'm going to test how shooting at 15 FPS will differ between: Angelbird - AV PRO CFexpress B SE - 512 GB and Angelbird AV PRO CFexpress SX - 160 GB. How many shots can I get off before buffer fills, and how long does it take for the buffer to clear?    MOP: X-H2 Factory rest, card formated, no lens (body cap on), performance boost on, manual exposure, mechanical SS @ 1/8000, IS off, Shoting RAW Compressed Lossless with only one card in. Held shutter release till buffer filled, and used stop watch to see how long for buffer to clear. Subtracted two frames from total taken as that's how long it takes me to release the trigger once the buffer is full. Repeat 2x for sanity check.   ***TEST RESULTS***   ~~~64GB Lexar Pro SD 150MB/s~~~ 75 shots to fill buffer, 36 Seconds to clear it   ~~~Angelbird AV Pro SX 160GB~~~ 251 shots to fill buffer, 5 Seconds to clear it   .~~~Angelbird AV Pro SE 512GB~~~ 232 shots to fill buffer, 4 Seconds to clear it     ***Conculsion***   If burst shooting an X-H2 at 15 FPS is your thing, buy the Anglebird 512GB SE for the same price as the 160GB SX.   Below is a shot on X-T2 w/ the Fuji 70-300. I manged to fluke it off with a dead battery by turning the camera off and on again, and squeezing three more shots out (this was the last shot).   Ta for now!
    • Xt5 firmware updated and now cannot see pics taken on lcd when pressing playback. Any ideas please? Elie
