I have just put my name down for a Fuji X100v as a carry all camera in support of my X-S10.
Since purchasing the X-S10 I have fallen in love with Fuji cameras and think that the X100v will be a great pocketable/small bag camera.
I have a few questions that I have been unable to answer by searching on-line.
1. How does one set up the camera for back button fucus?
2. If I fit the water proofing adapter and filter is the lens cap still useable?
3. How important is it that a lens hood is fitted? Does the lens need it? I have seen a number of videos of pro photographers using the X100v without a lens hood.
4. Any other advice would be appreciated.
Many thanks, Dave.
The simplest way to enable back button focusing is to switch to the M-Focus  mode (slider on the left) and use AEL/AFL button to trigger focusing. Let me know, if that is not good enough for you, and I can show your other relevant settings.
Thankyou for your reply.
It has been a while since I posted this request and I have worked out back button focussing. I use single focussing in conjunction with the AEL/AFL button. I do appreciate your reply however, it was good of you.
Dave.
On the X100V the combination of filter and lens cap provide three functions: to make the camera weather (not water!) resistant (WR), to protect the front lens and to reduce the chance of flare and ghosting. Whether you want to make the camera WR, is entirely up to your shooting conditions. Remember, many tens of thousands of X100's in various versions have survived without being WR at all, so with a bit of care, you can also do without. Protecting the front element of the lens is a similar personal choice. Know that most damages to front elements occur while dropping the camera. A lens hood will only protect against that to a certain level. Another source of damage (scratches) is while the camera is in the bag or in a pocket. In that case lens cap will protect equally well, if not better. Finally, the lens of an X100V is not very prone to flare and ghosting, but if you shoot in direct sunlight, a lens hood will certainly reduce the chances to that. If not directly visible, often the reduced contrast is a telltale. Note: if you do decide on mounting a filter, make sure it's a good one with multicoating (B+W, Hoya, Fuji...). Cheap filters can ruin your images almost unnoticed.
Thankyou all for the replies. I have installed the Fuji filter kit and have found that my old Olympus OM1 49mm lens caps fit on the filter perfectly. I now have the excellent X100v with a momento of my early film photography years.
A very happy Fuji user.
    • Perhaps matrix/evaluative metering mode would be a better choice in more circumstances. We need to be aware of how the camera will see the scene and choices it might make, I find having the viewfinder set to "exposure preview" or whatever it's called is helpful in knowing when to apply exposure compensation.
    • This is what I found on a firmware update that seems to address the problem. However, firmware version is at Ver. 211 already. As stated above this occurrence only happens using the EVF and at apertures between f2.0 and 3.6. It does not happen using the OVF or LCD. The firmware update Ver.2.11 from Ver.2.10 incorporates the following issue: The phenomenon is fixed that when pressing the shutter button halfway under certain conditions, the live view can flicker.
    • Hi! Thanks for this comment! Yes, although I'm utterly happy with my X-T50, small, light, sharp pictures, Xapp functioning, I've got to know that the camera tends to emphasize contrast in contrasty scenes. In a way this is strange to me, as X-T50 mostly exposes very well. This is especially expected with photos with foliage. Of course, I would like that the behaviour would be different. When I'm taking travel and such pictures I choose for JPG format (not HEIC, as Mac's Photos opens them oddly very slowly; iPhone's HEICs open fast ...). With JPG I've chosen to use the DR400 setting, but the problem is still there. For "more important" photos I of course use the RAW format. Regards, T.
    • Congrats on your Fuji! Since the receipt is in your relative’s name, they’re technically the original owner for warranty purposes. Some manufacturers, including Fuji UK, may allow a warranty transfer if you contact them and explain it was a gift. You could either ask your relative to make any initial claim, or reach out to Fuji to register it under your name as the recipient of a custom gift. Since it hasn’t been registered yet, it’s a good time to check with them.
    • Hi Dolores! 👋 Nice to meet you. I’m pretty new around here and just starting to dive deeper into the Fuji world, so it’s really cool to hear about your journey through all those cameras! How are you liking the X-T4 compared to the X-T2? I’ve been thinking about upgrading at some point and would love to hear your thoughts.
