Focus Bracketing Auto Greyed Out
Katiegm
Hi everyone. I am taking a macro photography class so I am anxious to use the focus bracketing feature on the XT4. I have watched several videos and they all talk about in the Focus Bracketing settings in the menu to select auto and then set your first and last focus spot. I can never get that far because Auto is always greyed out. So I tried manual and made all the selections. When I exit the menu, on my screen, BKT is in a yellow circle with a line through it and the camera only takes one photo. I have double checked my drive setting and bracketing in other modes works. I did turn Image Stabilization off since I am using a tripod but I didn't think that would affect anything. I am in full Manual  mode but  I have tried it with manual or auto focus.
Can you think of any reason why Auto is turned off and BKT is in yellow, and the camera only takes one photo? I have to submit three photos this week so I am desperate to figure this out.
Thanks
