2 hours ago, FujiCHA said:
What would be a reason to shoot without a lens?
To use vintage manual lenses or any len's which is not specifically designed for fujifilm mount or any totally manual len's which doesn't have electronics etc...
Ah, so not literally "no-lens" shooting; but rather, "no Fuji lens" shooting.
yup, kind of hehe, that's why most people enable it while setting up the camera, since most fujifilm shooters use manual focus lenses etc.. at least a few times for fun of using it.
