4 minutes ago, MudMan said:
Have you tried removing the add-on shutter button?
Thanks for your reply and feedback, yes you can see in 1:18 of the video I test it without the add-on ;)
This button is driving me mad, it's such a small thing, literally just a few mm of travel distance, but it feels wrong.
On 1/13/2021 at 1:16 AM, Ned_Sayer said:
I Just got a Fuji X-T3 from Amazon Warehouse deals, and the button feels off...
I used a X-T1 and have a X-t2 and they both feel very different to the X-T3.
I made a video to ask if this is how the X-T3 works or if I got a "faulty" unit.
it's defective piece . i suggest you to return and replace the camera !. hope this helps !. have a nice day ahead !
7 hours ago, Mr.B said:
I've been wondering the same thing. I purchased an X-T3 a couple of months ago and have the same issue. It doesn't feel normal to me.  I also have an X-T20 which does not do that.
I brought up this issue to amazon, and showed them this video, they offered a 10% refund... for a camera that costs around $1000 that is a lot, but not nearly enough to fix the problem by Fuji, as they would charge $200-$400 for the fix.
p.s. amazon said that I'll be able to return the camera as defective at any time, should I decide that the problem is unbearable.
Don't know if this helps but yeah, Amazon's 2 year guarantee seems to have worked for me.
you should return and replace from amazon , how long since you bought the camera ?
  • 3 years later...
Hey, I have just bought an "excellent" condition XT3 from MPB in the UK. I went out for my first shoot with it as soon as i unboxed it and something just felt off. I have the exact same problem as yourself. Did you get it repaired or did you return the unit? im unsure of what to do
Edited by Jackda02
    • Hey everyone, I am new to the fujifilm system, and I just received my X100vi about 15 days ago, and yesterday I noticed that ISO and exposure dials are acting up. I spent hours watching YouTube videos and reading forms without finding any solutions. Using ChatGPT or Gemini also didn’t help. My issues are the following: If I want to set my ISO at a specific value then the camera LCD/EVF shows a totally different value. For example, I have shutter manual, aperture manual and ISO dial at 6400, the camera shows ISO at 4000, when I take pictures it will show ISO at 4000 and not 6400. When I try to choose another ISO value it will skip some of the available values that are shown on the dial. Another issue I am having is when my exposure dial is not set at specific value, then I cannot set ISO to Auto no matter what value I select on the dial. If I do select the different exposure compensation values, then I choose A for ISO, the camera will activate the front commend dial to manually change ISO values. To get in Auto ISO, the shutter speed cannot be set in auto and the ISO dial should be set at 125, when I turn the ISO wheel, it seems like the numbers are misaligned by one value, If I put the dial on A with shutter speed manual, then it will trigger the front commend dial. The other issue that I am having is when I have Aperture, shutter speed and ISO on manual, If I change the exposure dial compensation + or - , it actually changes the exposure of the picture as well as the ISO value, which as I understand, if Camera is in full manual, the exposure dial should do nothing. The last issue that I am having, if I do have ISO in manual at a set value, and adjust exposure compensation dial, it alters my ISO instead of my shutter speed or my aperture, even though ISO is in Manual and the other two dials are in Automatic. I am not really sure if all of this is by design and I am just not understanding how everything works together, but it seems really odd how everything changes. Resetting the camera settings didn’t help.
