USB-C charging with X-T3 after updating to Ver.4.00
Tin Do
Hey guys!
So I just updated my X-T3 to the firmware Ver.4.00 and I can't charge the camera via my USB-C Apple wall plug.
No green light on the back of the camera but the white plug symbol does appear when plugged in.
The only time when the X-T3 is charging via USB is when the camera is turned OFF and connected to my MacBook Pro or Powerbank.
Does anyone else experience this problem?
10 hours ago, Tin Do said:
Hey guys!
Here it is , check this .i had mentioned the possible reason for this . I hope this helps , have a nice day !
