The focus ring on my Fuji X-A3 has stopped responding. No matter how much I turn the ring, the display still shows F 0.0.
What can I do?
What can I do?
try removing the lens and mounting it again ! , movement in contact between lens and body sometimes cause this . i hope it helps . have a nice day !
22 minutes ago, menoratse said:
Thanks, but I've already tried that multiple times.
Also, when the lens is mounted, the zoom works (indicating that there is a connection between the camera and the lens) but the focus ring doesnt.
then i guess , it's better to contact fujifilm service .and let them check if there is any manufacturing defects ,in that case they'll fix it or replace it . i hope this helps . have a nice day !
Something else is going on ... The F number is telling you what the aperture setting is, not what the focus is. If you are using a lens without an aperture ring, you have to set the aperture ( F number ) by way of changing a menu setting, not by twisting the focus ring. Also, if you have the camera set to auto focus, twisting the focus ring will not do much.
Which lens are you using?
Hi Jerryy,
The F number usually changes when I readjust the focus ring, so I've come to associate the two. Thanks! Learned something new today 😃
I'm using the standard lens that came with the camera, this is printed around the lens:
"Fujinon Aspherical Lense, Super EBC XC 16-50mm 1:3.5-5.6OIS II 58-diameter"
If it is a menu setting, do I just look for aperture settings?
That lens does not have an aperture ring, the f-stop has to be changed using a different method.
What you were seeing is because the lens is a variable aperture type that had its f-stop set using, probably, the auto setting from the body, As the zoom changed, the exposure changed and the camera reacted by changing the f-stop.
http://fujifilm-dsc.com/en/manual/x-t10/menu_shooting/aperture_setting/index.html
This may help, I do not have a manual for the X-A3 handy, so I am not certain how to tell you to navigate all of the menus to find all of the setting that apply to aperture and exposure and dig out which one got changed to cause what you are seeing. Advising a full reset may fix the current issue, but not give you an idea about how to stop it from happening again.
    • Yes Is some small amount leftover from the spot i cleaned. Inside only very less point of dust,yes my be are from manufacture Is very microscopic. anyway on pictures i not see dust and i not see the spot i clean. thankyou so much for your reply Is beautiful im Happy.Have a good day
    • Are you certain the spot is on the inside and not some small amount leftover from the spot you cleaned? Maybe try a different brand of lens cleaner, but make sure it is safe for lenses so that the lens coatings are not removed. Even weather resistant lenses can get dust inside, the seals can only keep out so much dust and zoom lenses are known to get dusty on occasion. More so than prime lenses do. Weather resistant means more sealing, but achieving perfect sealing is tough to get. It is also possible the dust has been there from the time it was manufactured and you are only now noticing because of the white dot. Does the dust show up in any of your photos? As far as cleaning cost goes, your local camera repair shop will be able to give you some estimates, prices will be different depending on where you are.
    • You may have to wait for next Easter and try again then.
    • Hello, After a long travel i see a micro white point on lent. I try with a product clean but not gone. After i try 50 time very gentle in many days. The micro point are gone but still a micro micro point. The lent Is 16/80 fuji. After  if i look lent in the direct sun i can see some micro points of dust. Very less but the lent on paper Is water resistent. So how can have micro point of dust inside? Anyway how i can clean or where i can go for clean my camera and how much can costly? Thankyou everyone
    • Update: the camera seems to have self-corrected. 🤷‍♂️  My working hypothesis is that moisture caused it to glitch, and after drying out, it's working again.
