I had Nikon AF 300mm f4 at the time purchased X-E1. It was tough to focus using viewfinder, and almost impossible when using screen handheld. So just sold that glass as well as other Nikon stuff.
X-E2 and X-E2s have lower magnification mode in the viewfinder comparing to X-E1, and it makes focusing with all lens noticeably easier for me. I've realized that price went dramatically down for Nikon AF glass, and just purchased AF 300mm again almost two times cheaper then sold it in 2013.
Here's one of the result from this lens on X-E2s. I've purchased lens for bird shooting, but didn't catch nice bird yet : )
it is one of the best lenses that nikon ever made. Much more compact that it’s big brother 2.8, was much appreciated by people whom wanted to shoot with a lens lighter (and cheaper) than the that!
The IF makes focussing relatively easy because you don’t have to rotate the barrel all that much.
Of course this on a aps-c results in an angle even narrower than originally intended.
One of the benefit of this AF 300mm f4 model - its focus limiter ring. It's designed to set Autofocus limit range, e.g. infinity - 5m.
Nikon AF lens often allow focus ring to bypass the infinity (which is required for more effective autofocus).
So when I focus on far objects manually on Fuji X, it takes time to catch the infinity point.
The focus limiter allows to limit max focus ring range on exact infinity point. So I don't need to hunt for that anymore and simply rotate focus ring until it stops.
well, the sensitivity is of any long lens because of, as you also say, of the motion blur and air distortion due to air movement  caused by the air mass moving due to thermic fluctuation in the air between where you are and where the subject far away is.
Great picture! I’ve always like this lens which was always considered the poor relation of the 2.8 but which on a mirrorless with EVF ( which acts as an image luminnosity amplifier) has come into its own.
The lack of autofocus though ( even with the focus limiter) makes this lens very difficult to be used on dynamic subjects.
    • Found the simple answer to my own question. Having assigned Auto ISO to the rear dial, I only have to push in the dial to make the Auto ISO options appear, then turn the dial to choose. Nice and fast.
    • Hello All, I am returning to photography after a decades-long hiatus that was prompted by my loss of access to a darkroom. Digital rendered that excuse moot, so I now return with a recently purchased XT5. I am from the Hudson River Valley in New York where I have spent the past five decades engaged in environmental work, mostly on the Hudson. I teach at Pace University where I direct the Gale Epstein Center for Technology, Policy and the Environment. My project ahead is documenting the unseen Hudson, a combination of the obscure, under-appreciated, and invisible - a street-style approach to people, places and things that make the river what it is. There will be little landscape, if any. The "Mighty Hudson" is well-documented. If nothing else, it will be a mission-driven project to bring me back to photography while learning my camera. I look forward to everything this amazing site can teach me. Cronin
    • Hi,   I would really appreciate if someone could answer this question. Is it possible to have the X-T4 shoot in AF-S for photo mode and AF-C in video mode while the front lever is left at AF-S?  If so, how would this be done or wher in the menu system would I set this up? This is similare to setting the apeture at f/2.8 for photo mode but fioming at f/4 in video which I already have setup. Thanks and kind regards
    • According to the manual you can assign auto ISO to any one of the function buttons but I've never tried it. (It's not something I frequently change so all my function buttons do other things.)
    • Hello, I have a new xt5 and have enjoyed its setup, until now. I hope someone with patience can help me through my ISO dilemma. My question: I have assigned settings for Auto ISO 1,2 and 3.  Should I be able to select Auto ISO 1, 2, or 3 for a shot? If so, how?  Or is the camera supposed to. At present, my screen shows Auto ISO 3, and never changes. I assigned ISO to the rear dial to no effect. Of course, when I half depress the shutter button is see the actual ISO in real time, but the function of the Auto ISO and how to control it has me confused. Thanks for any help.
