Why can't I put the format option in "my menu"?!?!?
There is a few things you cannot put in "my menu", and format is sadly enough one of them. I cannot see why they have put this limitation to my menu, but then this is the first iteration of the new UI and I reckon it will be adjusted and refined over time.
;-D Hans
