Ah.
You can change always the lens. It depens on what you are using the cameras for. If you are making landscapes, for example, with the T1, beacuse it is seald, and it has more protection to the and, and wind, put the lens on this camera. I think that the OVF is not useful with this focal length, and if yo are going to use the EVF, may be is better the T1.
xpro1-no tilt screen, evf not so good as xt10,maybe I will go netter with 14mm on xt10,and 18-55 on xpro1.Mainly concerning is about. ..I am just learning how to deal with a 14mm,its kind of weird lens for my point of view
