When a new firmware for X-H1?
bergat
The X-H1 is capacity of x-t2 with the plus of the ibis.
I ask to myself when Fuji will develop the capacity of AF tracking and eye af velocity to make them almost equal to x-A7 features?
Do you think Fuji will let die its admiral camera?
Edited by bergat
    • Hi all, I notice that there are some focusing sound on my XF33 despite it being said as completely silent in many review. The focusing sound is kind of like stepping motor sound, and it only appears when I’m shooting photo. I try shooting near and far away and there is sound. However, it is completely silence when I shoot videos. Is it normal or do I need to change some of my setting? Or am I just getting a not too good copy haha. please assist me with the matter guys! Thanks!
