I recently started reading about focal reducers and it sounds like an interesting concept. But I can't find any information about when it can be used and when not and what the drawbacks are. In particular I wonder about:
- Does the lens have to be a full frame or can you use an APS-C lense?
- Could you make the Fuji 10-24 into a super super wide angle 2.8 lens?
Does anybody have a link to an article that explains the basics or can explain here? The adapters I have found a re a little too expensive to just try out.
focal reducers, as you call them, are meant to adapt old lenses on cameras with a sensor smaller than 24mm x 36mm so that there is no magnification used on a smaller format compared to their original one when used on a larger format
They gain you also a stop.
They don’t work with all lenses because a lens protruding too much inside will touch the optical elements which they contain.
You cannot use it to make a fuji lens wider than it is.
just google  the words focal reducer and fujifilm X, you will find plenty of information
focal reducers, as you call them, are meant to adapt old lenses on cameras with a sensor smaller than 24mm x 36mm so that there is no magnification compared to their original one when used on a large
Thanks for clarifying. There is a lot of information on the web but none as concise as your response :-)
