Hello everybody!
There is a problem with the SMC Takumar 50/1.4 lens.
I have a Fuji X-T10.
I bought lens on ebay from Japan - SMC Takumar
Also bought an adapter - Adapter
When installing the adapter and lens there is no focused image, the image is blurred.
The manual focus wheel on the lens does not adjust the focus.
The settings on the camera are set correctly - the focus is transferred to the manual mode, the mode "Shoot without lens" is set.
What could be the problem? Adapter? Lens? Camera settings?
Examples of photos attached.
I would be grateful for any help.
Ilya.
Edited by Ilya Azar
that adapter is too short (as written in the description).
Try to find a "PK-FX" or "K-mount - FX" adapter. You need a correction of the flange distance from Fuji X-Mount (17,7 mm) to Pentax K-Mount (45,46 mm), so the adapter should be 27,76 mm long.
On 3/25/2019 at 12:31 PM, Ilya Azar said:
Hello everybody!
How did you get the lens (pk) to fit on the adapter (m42) since they have different mounts?
Assuming the lens you posted is what you have, you'd need a Pentax K to Fuji X mount adapter like this: https://www.amazon.com/Fotodiox-Lens-Mount-Adapter-Mirrorless/dp/B008BBI994
I've used numerous Pentax and Takumar (m42) lenses adapted to my Fuji cameras without any issues.
Edited by plaidshirts
Thank you very much for answers. I bought this adapter https://ru.aliexpress.com/item/High-Precision-M42-FX-Lens-Adapter-for-M42-screw-Mount-Lens-To-for-Fujifilm-X-Pro1/32745938005.html?spm=a2g0s.8937460.0.0.5f212e0eCOOE88 and now everything is OK. Thank you.
Takumar 50/1.4. Fuji X-T10. F1.4
    • Hey everyone, I am new to the fujifilm system, and I just received my X100vi about 15 days ago, and yesterday I noticed that ISO and exposure dials are acting up. I spent hours watching YouTube videos and reading forms without finding any solutions. Using ChatGPT or Gemini also didn’t help. My issues are the following: If I want to set my ISO at a specific value then the camera LCD/EVF shows a totally different value. For example, I have shutter manual, aperture manual and ISO dial at 6400, the camera shows ISO at 4000, when I take pictures it will show ISO at 4000 and not 6400. When I try to choose another ISO value it will skip some of the available values that are shown on the dial. Another issue I am having is when my exposure dial is not set at specific value, then I cannot set ISO to Auto no matter what value I select on the dial. If I do select the different exposure compensation values, then I choose A for ISO, the camera will activate the front commend dial to manually change ISO values. To get in Auto ISO, the shutter speed cannot be set in auto and the ISO dial should be set at 125, when I turn the ISO wheel, it seems like the numbers are misaligned by one value, If I put the dial on A with shutter speed manual, then it will trigger the front commend dial. The other issue that I am having is when I have Aperture, shutter speed and ISO on manual, If I change the exposure dial compensation + or - , it actually changes the exposure of the picture as well as the ISO value, which as I understand, if Camera is in full manual, the exposure dial should do nothing. The last issue that I am having, if I do have ISO in manual at a set value, and adjust exposure compensation dial, it alters my ISO instead of my shutter speed or my aperture, even though ISO is in Manual and the other two dials are in Automatic. I am not really sure if all of this is by design and I am just not understanding how everything works together, but it seems really odd how everything changes. Resetting the camera settings didn’t help.
