Having seen the fuji trade-in Promotion ( am about to press the trigger and wondered if I should get a silver or black version. I am leaning toward the black. What do people prefer?
Another excellent promotion that I saw in the UK was £150 off the 18-135mm lens (https://fuji-offers.com/uk/en/pages/cashback-0615/qualifying_products). I think this would be a versatile combo for the X-T10 - what do you think?
Thanks
Lots of food for thought in this thread (including a shockingly detailed response from me):
http://www.fuji-x-forum.com/topic/538-x-t1-graphite-silver-vs-black/
It's theoretically about the X-T1 but the responses also apply to the X-T10 (which has the materials/colors of the X100x/X-Ex line where silver is the "true" color and black is "painted on" rather than X-T1 where black is the underlying material and GS is "painted on")
I usually prefer silver on Fuji. (I am going to be very angry if the Pro2 is only made in black, again.) When the first images of theX-T10 came out, it was the first body which I thought looked cheap and bad in silver and better in black. When I went to pick my X-T10 up, I got to make my choice in person and I went for silver. It looks just as good in person as silver does on every other Fuji. I don't know why the promo pictures all make the silver X-T10 look tacky—maybe they shot it with a polariser on—but ignore them. If you like silver on other Fuji's, you'll like the silver X-T10.
Of course, if you like black on other Fujis, you'll prefer black on the X-T10.
The Graphite SIlver X-T1 isn't really relevant because that's a different finish method and does look different. It's more sparkly and generally a more genuine metallic finish, and a tone darker. The silver used on other Fujis, including the X-T10, is brighter and smoother.
As for the 18-135, it's a very 'eh' lens. If you detest changing lenses and you have to cover absolutely everything, it's your only choice. If you simply want to cover most things, get the 18-55 instead, it's a much better optic. If you want the best optics and want to cover a good range, go with primes. The cashback offer is good for the 18-135, but it's even better if you buy two or more prime lenses: £75 back for the first lens, £150 back for every additional lens after that. Three lenses gets you £375 back, which is pretty much the cost of the 35mm f/1.4 lens; buy two other primes, get the 35 for free, effectively.
The other benefit to primes or the 18-55 is they don't dwarf the X-T10 as much. Do not underestimate how small and light the X-T10 is, and how huge and unwieldy that makes larger lenses feel. The 18-135 is significantly larger than the X-T10. The 18-55 is smaller than the 18-135 and a lot lighter, and is in fact lighter than the X-T1. The 56mm, 16mm and 90mm primes are all larger/heavier than the X-T10, but every other prime is smaller/lighter and balances well.
It's funny how badly we all reacted, when the final product was totally fine and what we'd expect from a smaller X-T1. Something about how the front command dial looked was bad I think, which ultimately makes sense since the front command dial is easily the lowest quality part of the X-T10. It's still better than the squishy, wearing-a-condom feeling of the dial on the X-T1, but it's made of cheap plastic and still has more squishiness than I'd like. The dial on the X-E1 was perfect by comparison IMHO: Rounded nubs and made of dull ballistic-looking plastic, it felt like something from a submarine rather than something from a dollar store FM radio.
It's squareness/height was the other aspect that turned people off, but that was just lack of familiarity. In hand it's obvious that the height is absolutely necessary to make the camera holdable for people with normal size hands. The half-case adds height and that's a good thing, without it I'd be dropping the camera constantly.
Either way, the silver metal on the X-T10 is completely satisfactory just like on the X-E1.
    • My very much loved X-Pro 2 has a serious problem for a long time but I can’t help myself, it’s too good to just sit on a shelf.    Last year the display had started weird pink colors and the camera was freezing after a few seconds. First I thought the screen was the problem but when I get into the menu at once, the screen looks fine. After some seconds or when I am trying to get the the configuration part of the menu, the camera will freeze again.    when I turn it off the screen stayed on for about a second. But I can’t turn it on again even after the screen finally went black. I need to remove the battery and insert it again and then I can turn it on again. But the problem is there again and again. today I saw that there was a new firmware update 5.11 that is said to fix a freezing problem and I thought to give it a last try. Ironically I could successfully make the firmware update with no problems. Somehow terrifying to make a firmware update when you don’t know if the camera might freeze during the process. But everything went fine. Problem is the same as before. I tried different batteries and different lenses and without a lense. Always weird pink colors on the screen and finally freezing. Any suggestions from the community?    Or perhaps help from Fuji?
    • I repeat - there is something wrong. I have the same lens and an x-t5 and do not experience any sharpness problems. It may be that there are problems with a 150-600 lens, I don't  know, but mjoseph67 is using the 16-55. Make sure the af is set to focus priority and that you do not have af with mf set (if you have you could be accidentally moving the focus ring after autofocus). If that doesn't help get your camera and lens checked out.
    • Perhaps matrix/evaluative metering mode would be a better choice in more circumstances. We need to be aware of how the camera will see the scene and choices it might make, I find having the viewfinder set to "exposure preview" or whatever it's called is helpful in knowing when to apply exposure compensation.
    • This is what I found on a firmware update that seems to address the problem. However, firmware version is at Ver. 211 already. As stated above this occurrence only happens using the EVF and at apertures between f2.0 and 3.6. It does not happen using the OVF or LCD. The firmware update Ver.2.11 from Ver.2.10 incorporates the following issue: The phenomenon is fixed that when pressing the shutter button halfway under certain conditions, the live view can flicker.
    • Hi! Thanks for this comment! Yes, although I'm utterly happy with my X-T50, small, light, sharp pictures, Xapp functioning, I've got to know that the camera tends to emphasize contrast in contrasty scenes. In a way this is strange to me, as X-T50 mostly exposes very well. This is especially expected with photos with foliage. Of course, I would like that the behaviour would be different. When I'm taking travel and such pictures I choose for JPG format (not HEIC, as Mac's Photos opens them oddly very slowly; iPhone's HEICs open fast ...). With JPG I've chosen to use the DR400 setting, but the problem is still there. For "more important" photos I of course use the RAW format. Regards, T.
