  • 2 years later...
On 10/23/2017 at 7:56 PM, malaladno said:
Hello,
My shutter has been stuck at 1/500 and I can't change it. I can move the shutter wheel, but shutter in camera doesn't do anything. I have been trying rotating wheel in front but that doesn't help. Anyone got any experience with this ?
thanks.
Have you found a solution?  Bc the same thing happend to mine yesterday
