I've been using this camera on & off for years, & have always set the image quality to Raw, but this option has mysteriously vanished. I'm on holiday & I actually set it to Raw before I came away but now the only options I have are Fine & Standard. Can anyone advise please? Have I changed some other setting that excludes Raw? I'm not aware of doing so.
3 hours ago, jerryy said:
Is the top drive dial set to one of the advanced or similar settings?
These settings are for jpeg only images, so the raw option would be disabled.
Thanks, but which top drive dial do you mean? On top of the camera I've got ISO, Shutter speed, on/off, that's all (plus the dial on the right for increasing / decreasing contrast).
On 10/27/2025 at 8:27 AM, Alami1906 said:
OH! I hadn't even noticed that the dial had moved from S! Thank you! 🙏🏼 This is something I hate about this camera - this dial moves on its own, you can't fix it so it doesn't move onto a different setting! 🤦🏻
I don't have an X-T3 to check and it doesn't mention in the manual but its possible that you can lock the dial using the LOCK option in the Button/Dial Setting menu
