hey everyone, this is my first fujifilm camera and I'm scared of that the fact that it has been turning off every time I turn video recording on. either from manual or movie mode.
things you should note -
- I use the sandisk SDXC card 128GB which is supposed to be *for* 4k recording.
- the battery is fully charged.
- the settings to at least change it from 4k to a lower resolution are all greyed out in both manual and movie mode.
any help is appreciated, thank you so much!
Do you mean that the camera completely powers off when you start to record a video?
Not sure why it would do that unless there is a fault but if the setting to change Movie Mode is greyed out you might have the High Speed Recording Mode turned on - at least try turning that off but it shouldn't power off the camera.
There is always a chance its a card problem - do you have a different card you could try?
Is the battery fully charged?
I have the proper sandisk SDXC v30 card that's used for 4k. the battery is fully charged.
however -
1. I updated the firmware but it's still the same.
2. the battery that the sellers sent is actually third party. it's by a company called batmax. I'm wondering if that is the cause.
3. the high speed recording mode is also greyed out so turning it off is also not an option.
    • Hey everyone, I am new to the fujifilm system, and I just received my X100vi about 15 days ago, and yesterday I noticed that ISO and exposure dials are acting up. I spent hours watching YouTube videos and reading forms without finding any solutions. Using ChatGPT or Gemini also didn’t help. My issues are the following: If I want to set my ISO at a specific value then the camera LCD/EVF shows a totally different value. For example, I have shutter manual, aperture manual and ISO dial at 6400, the camera shows ISO at 4000, when I take pictures it will show ISO at 4000 and not 6400. When I try to choose another ISO value it will skip some of the available values that are shown on the dial. Another issue I am having is when my exposure dial is not set at specific value, then I cannot set ISO to Auto no matter what value I select on the dial. If I do select the different exposure compensation values, then I choose A for ISO, the camera will activate the front commend dial to manually change ISO values. To get in Auto ISO, the shutter speed cannot be set in auto and the ISO dial should be set at 125, when I turn the ISO wheel, it seems like the numbers are misaligned by one value, If I put the dial on A with shutter speed manual, then it will trigger the front commend dial. The other issue that I am having is when I have Aperture, shutter speed and ISO on manual, If I change the exposure dial compensation + or - , it actually changes the exposure of the picture as well as the ISO value, which as I understand, if Camera is in full manual, the exposure dial should do nothing. The last issue that I am having, if I do have ISO in manual at a set value, and adjust exposure compensation dial, it alters my ISO instead of my shutter speed or my aperture, even though ISO is in Manual and the other two dials are in Automatic. I am not really sure if all of this is by design and I am just not understanding how everything works together, but it seems really odd how everything changes. Resetting the camera settings didn’t help.
