Any recommendations for other adapter brands?
As to the adapter questions, the single best adapter I can recommend for Canon FD mount is one I found on the auction site that is made in Poland. It is a unique 1 piece design that doesn't need the sliding ring that most FD adapters require to activate the aperture pin on FD lenses. You can view a video of its operation here.
https://www.youtube.com/watch?v=5CvB8n5wFPg
This is far superior to any FD adapter I have used. Every other one I have ever had has gotten loose and jiggly over time. This adapter solves that problem and it has the added benefit of being made in Poland to very high tolerances. In this modern "Made in China" world this is very refreshing. The maker/seller of the item on the auction site is ciecio7 and I can heartily recommend this adapter. The price isn't to bad and while it does take a while to get here it is well worth it.
I am owning this adapter too after reading this in http://www.fuji-x-forum.com/topic/325-old-lenses-for-dummies/. It's a really good one and I'm happy with it. The Ebay seller ships worldwide: http://www.ebay.com/itm/Canon-FD-FL-to-Fuji-Fujifilm-x-pro1-X-E2-X-T1-camera-x-mount-ciecio7-adapter-/251250771895?hash=item3a7fb687b7:g:i8IAAOxyoA1RUGKv
But maybe it's a lens problem so you have to be sure about it. My FD 50/1.4 SSC works really well.
Edited by KwyjiboVanDeKamp
Hello,
I was just wondering what FD-FX adapters people have had the most success with?
Specifically for the FD 50mm 1.4 SSC on the Fuji XE-1?
I currently have a Kipon adapter and it cannot focus at infinity with the FD 50mm. It is fine for anything up to around 5- 10 meters, but after that it is terrible.
I am not sure if it is a fault with the lens, the adapter or the optical set up with the flange difference created by the adapter.
Many thanks in advance for any help or info anyone has.
So, apparently I need an adapter that is 24.3mm (mount to mount). Any longer than that and it wont focus at infinity.
The Kipon adapter I currently have looks to be slightly longer (28-29mm), and so this might account for the inability to focus the FD 50mm at infinity on the XE-1.
Do you know the length of the adapter that you recommended in the above post?
Many thanks in advance for any help.
Don't think that this is the root of all evil. But have a look:
Any ideas which adapter is "better"?
Fotodiox, Fotasy, Metabones, Novoflex? The last 2 selling for $99 and a whopping $169!
Any feedback is appreciated.
I own nFD 50/1.8 and 28/2.8 and use them with with this adapter:
I haven't tried any of the more expensive adapters so I can't make a direct comparison, but the quality and fit is just as good as, if not better than, the Fotodiox and Fotasy adpapters I own for my m42 and om lenses.
Edited by plaidshirts
  • 1 year later...
I use focus peaking when in manual focus mode and it works beautifully with my Canon FD and my Nikon lenses and adapters. I also use my Canon screw mount lenses from my rangefinders. All are great lenses and I have put my Nikon DSLRs down and been going this route, since I have more flavors, tools, or lens palettes at my finger tips. I wish Canon and Nikon can put focus peaking onto there cameras. I have an X-E1 Fuji right now and I am considering getting a X-T2 and my Nikon DSLRs will get sold off. The Fujifilm cameras seem to work with my huge lens collection and I can carry my film Canons around and not worry about carrying too much equipment.
    • Hey everyone, I am new to the fujifilm system, and I just received my X100vi about 15 days ago, and yesterday I noticed that ISO and exposure dials are acting up. I spent hours watching YouTube videos and reading forms without finding any solutions. Using ChatGPT or Gemini also didn’t help. My issues are the following: If I want to set my ISO at a specific value then the camera LCD/EVF shows a totally different value. For example, I have shutter manual, aperture manual and ISO dial at 6400, the camera shows ISO at 4000, when I take pictures it will show ISO at 4000 and not 6400. When I try to choose another ISO value it will skip some of the available values that are shown on the dial. Another issue I am having is when my exposure dial is not set at specific value, then I cannot set ISO to Auto no matter what value I select on the dial. If I do select the different exposure compensation values, then I choose A for ISO, the camera will activate the front commend dial to manually change ISO values. To get in Auto ISO, the shutter speed cannot be set in auto and the ISO dial should be set at 125, when I turn the ISO wheel, it seems like the numbers are misaligned by one value, If I put the dial on A with shutter speed manual, then it will trigger the front commend dial. The other issue that I am having is when I have Aperture, shutter speed and ISO on manual, If I change the exposure dial compensation + or - , it actually changes the exposure of the picture as well as the ISO value, which as I understand, if Camera is in full manual, the exposure dial should do nothing. The last issue that I am having, if I do have ISO in manual at a set value, and adjust exposure compensation dial, it alters my ISO instead of my shutter speed or my aperture, even though ISO is in Manual and the other two dials are in Automatic. I am not really sure if all of this is by design and I am just not understanding how everything works together, but it seems really odd how everything changes. Resetting the camera settings didn’t help.
