Rear command dial cannot be programmed to do Focus Check
I had the same problem with my iPhone 15 Pro. I simply deleted the previous connection in the app and recreated it. Everything worked.
Hello 10 years later... So what I did is I cut the inner structure so it doesn't have to fit inside the body. Then I used a double sided tape. Poor camera even doesn't have a working screen. Or is it happy because I still care about it?
I popped by my local camera store to check out the GRX100RF today. They let me put my SD card in it and snap some pictures. I set it to ACROS and snapped these shots of the salesman. It's easy to see what camera brand he likes.
I have a copy of Tamron’s 150 - 600mm G2 lens. It has really good image quality and is easy to use. I have heard the one you are asking about is similar. Will you be able to test it? The only drawback for me with my lens is after carrying it around for a while, it gets heavy and so on the tripod it goes. Also, it was not a FX mount lens, so I use a Fringer smart adapter, but that has never been a problem.
Yeah the 17-40 wasn’t announced when I purchased mine so didn’t have that decision. I went with the mk II as I was impressed with what offered and the amount of size reduction they managed. I saw this that has pretty good comparison between the mk II and the 17-40 https://fujiframe.com/articles/sigma-17-40-vs-16-55-fuji
