When I bought my XT5 there was a dust particle in its sensor, I hadn't bought a blower at the time and decided to blow air into it, which caused 2 tiny drops of saliva to land on the sensor, I then had to use a q-tip to try and remove it but it left residues, which led me to buy a cleaning kit but as it turns out, it was for LENS. They had a camera drawn so I thought it can be used. Stupid me used the lens cleaner liquid on the sensor (sprayed onto the q-tip and wiped residue) and resulted in a bigger residue.
AND ON TOP OF ALL THAT, I didn't change any settings or turn my camera on while I attempted to clean it, so now I'm worried about the IBIS and shutter speed etc. or any other major damage this could have done. When I turn the camera on, everything works fine and it's not really obvious in the photos but you can def see the residue spots shade.
My question is, will the sensor cleaning solution still remove the lens solution residue (ingredients: water,isopropyl alcohol, surfactant)?
It's my very first camera. Sorry for my ignorance :(
I have used disposable lens cleaning wipes to remove this kind of residue before.  Get the zeiss brand, they tend to work best.  I use a q-tip instead of my finger to push the wipe around because my finger is way too big.  Usually have to do it 3 or 4 times.  Be gentile and slow.  If you get any cotton fuzz from the q-tip in there, use a proper rocket blower to remove that.
You can also try something like a lensPen. I have one of those too, but generally prefer the wipe method above.
In the future, to remove dust, I prefer to use an unsized nylon brush.  You use canned air on the brush, and this charges it electrostatically. Then wipe the brush over the sensor and mostly the dust is gone.  You can get the brushes typically on ebay or Amazon.
To check for sensor dust, take a photo of a clear sky at f22 or as high as you can go, at ISO125.  Then use spot detection in Lightroom.  Brush again if dust remains.
No need to apologize, hehe we all been there, camera care is tricky and needs a professional to do perfectly. But if you want to do the cleaning yourself you can try using Sensor Swabs by Photographic Solutions. The instructions are so easy to apply and they have a ton of videos showing step by step process on how to properly clean the camera lenses and sensors. Theyre products are safe and really effective especially on dust removal and prints and marks. I have been using them for a couple of the years and I have no problem cleaning my camera. Hope it helps
As above. Use a sensor swab kit. The right tool for the job is always best.
Make sure the camera is turned off (remove battery to be sure). One or two drops of cleaning solution on the edge of the swab, start at one side pull the swab slowly across with a single even movement pressing firmly and holding the swab at 45 degrees. Once at the other side (without lifting the swab) pull the sensor swab back the opposite way in the same manner. Discard the swab. Repeat with another swab if necessary. Do not use a swab twice as any embedded dust can scratch the sensor surface.
I've used these and they work well:
20Pcs 16mm APS-C Sensor Cleaning... https://www.amazon.co.uk/dp/B0B6P7L6FF?ref=ppx_pop_mob_ap_share
Edited by thelostkiwi
  • 8 months later...
    • Found the simple answer to my own question. Having assigned Auto ISO to the rear dial, I only have to push in the dial to make the Auto ISO options appear, then turn the dial to choose. Nice and fast.
    • Hello All, I am returning to photography after a decades-long hiatus that was prompted by my loss of access to a darkroom. Digital rendered that excuse moot, so I now return with a recently purchased XT5. I am from the Hudson River Valley in New York where I have spent the past five decades engaged in environmental work, mostly on the Hudson. I teach at Pace University where I direct the Gale Epstein Center for Technology, Policy and the Environment. My project ahead is documenting the unseen Hudson, a combination of the obscure, under-appreciated, and invisible - a street-style approach to people, places and things that make the river what it is. There will be little landscape, if any. The "Mighty Hudson" is well-documented. If nothing else, it will be a mission-driven project to bring me back to photography while learning my camera. I look forward to everything this amazing site can teach me. Cronin
    • Hi,   I would really appreciate if someone could answer this question. Is it possible to have the X-T4 shoot in AF-S for photo mode and AF-C in video mode while the front lever is left at AF-S?  If so, how would this be done or wher in the menu system would I set this up? This is similare to setting the apeture at f/2.8 for photo mode but fioming at f/4 in video which I already have setup. Thanks and kind regards
    • According to the manual you can assign auto ISO to any one of the function buttons but I've never tried it. (It's not something I frequently change so all my function buttons do other things.)
    • Hello, I have a new xt5 and have enjoyed its setup, until now. I hope someone with patience can help me through my ISO dilemma. My question: I have assigned settings for Auto ISO 1,2 and 3.  Should I be able to select Auto ISO 1, 2, or 3 for a shot? If so, how?  Or is the camera supposed to. At present, my screen shows Auto ISO 3, and never changes. I assigned ISO to the rear dial to no effect. Of course, when I half depress the shutter button is see the actual ISO in real time, but the function of the Auto ISO and how to control it has me confused. Thanks for any help.
