What to Get
I have the same problem on my x-t100 and the solution didn't work. It doesn't technically make sense, but I couldn't believe it worked for so many people. I thought pressure might have some effect. The problem is humidity, and pressure somehow removes it. The final solution was to dry it with a hair dryer, and it definitely worked.
Unfortunately, I don’t. And High Sierra is far too old for recent software.
I tried to restart the PC, and still the same thing happen, the connection is on and off. Tried different (worked well with macbook) and samething happen. But tried with PC laptop (Acer), then the connection is ok, so my desktop PC has USB port problem. Then I tried to use capture one pro 20, for live view, but it won't show up. May be you know the minimum version of C1 pro that support gfx100 live view tethering ? As my macbook limited to High Sierra 10.13, and can't install newer OS. I notice newest FUJIFILM TETHER APP may support live view, does it ? Thank you so much for your advice and tips, really appreciate it. Best regards from Indonesia
