Emergency button
Antvahl
Hi new to Fujifilm cameras. I want to assign a button which when pressed sets a preset aperture, shutter speed and ISO. I can only find custom options for film simulations, WB and other things.
Is it possible? I need it for unexpected moments for example if a bird comes flying low or something sudden appears when I’m photographing landscapes or stills. Then I want to quickly set a higher shutter speed, aperture around 5.6 and auto ISO.
Thanks!
Edited by Antvahl
On X-H2 you can assign any Fn button to be a toggle to bring you to C1 (Custom setting 1). So save your desired settings as C1 and assign an Fn button of your choice. (Asuming that X-H1 also has this function. If not, your option will still be to use one of the C settings, and then just use the top dial to go to it.
