Hi everyone,
My name is Martin, and I'm new to the forum. I wanted to share some videos and feedback I got from using a Speedbooster Ultra OM to FX in case any of you was wondering to get one.
1.- Unboxing
2.- Warning, some incompatible lenses
3.- Review with Zuiko 50mm f/1.4
Hope you find this videos helpful, let me know if there is anything you want to know about the speedbooster.
Cheers!
Martin
Thanks. Very helpful. I guess, it'll all depends on whether the 3rd party lens is worth it for the extra one has to pay for a speedbooster.
Glad you find it helpful, I agree with you but I don't think someone would by the speedbooster just for one lens. In my case I have 4 Zuiko lenses 24mm f2.8, 50mm f1.4, 135mm f2.8 and 80-240 f4 so by adding the speedbooster I bastly extend my optics options on the XT1
Plus, they haven't let me down! ;)
15373509326_0d0ac504c7_z.jpgSun by
16861727990_4c2e1d530a_z.jpgBlue steel by Martin Cervantes, on Flickr
