Is there anyone who have owned or owns a Voigtlander lens, either adapted, or with native Fuji mount that can share an opinion on what the experience look like?
I do mostly street photography, and I switched to automatic lenses after having used manual lenses for quite some time.
I thought, after enjoying the automatic experience, I wouldn't be able, or neither like the idea of going back to manual.
But then, for pure coincidence, I put an old manual lens back on my X-Pro2 and I liked it again.
Now, my old manual lenses are fun to use, and somewhat give interesting results, but aren't exceptional lenses by any mean.
So, I stumbled upon the Voigtlander and I thought the render of those lenses is definitely something.
But they're not exactly cheap either. Therefore, before committing, I would greatly appreciate some insights from people who actually used them on a Fuji system.
I'm specifically looking at:
(adaptable)
Voigtlander 35 f/1.4
Voigtlander 40 f/2
(Fuji mount)
Voigtlander 35 f/1.2
For some reason, the samples I saw of the 35 f/1.2 don't look as exceptional as the 35 f/1.4, but it could be a coincidence.
Edited by verysame
    • agreed on the upload but based on the location and number it sounds exactly like the storage slot 1 status icon
