I've had my Fujufilm XT200 for almost a year now and it normally doesn't make any noises when I turn it on or use it but the past 2 days, there has been a humming noise or low fan noise coming from the body. I didn't change anything in the settings and I even tried to turn off IS mode to see if thats the problem. I've searched and saw that Fuji's with IBS sometimes has this problem, but to my understanding the XT200 doesn't have IBS. Does anyone have any idea why this noise is happening all of a sudden and is there a way to fix it?
I've been using the same kit lens, 15-45, it came with so I don't think lens would be a factor.
    • I am very tired of Fuji as a whole... They automatically deny responsibility on issues, quote crazy high repair prices and timeframes and when I accepted a (refurbished" replacement 100-400 instead of a repair because to would be cheaper and faster it developed the exact problem a couple years later, My XT4 is absolutely unreliable because of the turn on turn off issue that has persisted through numerous attempts to fix it and my 10 to 24 would not focus at infinity and struggled to focus at all, and I went through two of them because of focus issues. My sigma is much better.
