Xs10 and Fuji app
Is it just me or is the interchange between camera and app just crappy?
First of all the iOS app won’t rotate to landscape mode (hello iPad?)
the menu terms/instructions differ between app and and camera (firmware v2.2)
you need Bluetooth AND wifi for a connection.
when I get it to work once it won’t reconnect the next use without resetting the connection.
ain’t no way I’m going to trust it with applying a firmware update wirelessly.
  • 10 months later...
